16 กรกฎาคม 2561, 13:49:43
ผู้เขียน หัวข้อ:  27.10.2009 - Phoenix Service Software - 2009.34.7.40015  (อ่าน 2163 ครั้ง)
FixPhoneLamnarai^
..:::Support File By Wintrsla2003:::..
คะแนนขอบคุณ: 8145
Member ID : 5281
Time Online : 108:14:6
Level 52 : Exp 67%
PD: 1.091
กระทู้: 4197
« เมื่อ: 28 ตุลาคม 2552, 12:13:19 »
Changes/improvements made from previous version 2009.20.10.39068:
New features:
    * Touch Screen Calibration
    * ALS Tuning Wizard
    * Error corrections & changes:
    * Flash Update Package 09.042.032
    * New rf_losses.ini
    * Product Code change improvements for RX-51
    * Dynamic Country of origin in label printing shows country names in clear text if product specific configuration / data package supports it.
    * Several improvements for the RX-51 product, please refer to product specific Service Bulletins for further instructions
    * Changes to DCT-4 IMEI / ESN rebuild.
Known errors & limitations:
    * Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept.
    * Flashing with FLS-5, SS-46 and product specific adapter is not reliable for all BB 5.0 products.
    * If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong. This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8.
    * Multi Flash has limited capabilities, launch Multiflash UI first and then connect phones one by one, do not attempt to service more than 5 phones at the time
    * Some phone models request SIM Lock data to be written in wrong format. You should use special DLL as a workaround for this product software related problem. Please see Common SB SB-102 “Tucson Add-On Components for SIM Lock version
    * While performing restore or variant change operations with Tucson system firmware update as a separate activity may increase stability.
    * DCT-4 IMEI / ESN Rebuild functionality is limited. Corrections will be available when new Flash Update Package is released during week 45/2009
    * Operating band reading / writing may not work for all products (e.g. RM-159), due to implementation in phone SW. Phoenix modifications will be available in an additional Phoenix release estimated for week 43/2009. This function can also be done via phone keypad.
    * Refurbishment flashing and product code change for RX-51 product requires SX-4 card to be available
    * FPS-21 flashing for RX-51 works only with TCPIP connection, if FPS-21 prommer HW is older than 10. USB connection works if FPS-21 HW is 10 or newer.
DOWNLOAD LINK:
  http://rapidshare.com/files/298674160/Phoenix_Service_Software_2009_34_7_40015.exe
ลิงค์หัวข้อ: http://wintesla2003.com/topic/102444
รับงาน ส่งซ่อม Hardware&Software
สอบถามโทร : 080-2619914 (ตั้ม)
ซ่อมไม่ผ่านไม่คิดเงิน
รับปลดล็อค iPhone4/4S/5 3GS 6.x.x LL ราคาพิเศษ
PD: 0.717
« ตอบ #1 เมื่อ: 29 ตุลาคม 2552, 00:54:14 »
อย่าลืม ตัว patch น่ะครับ
แฮ่
sumek
คะแนนขอบคุณ: 170
Member ID : 4273
Time Online : 51:7:4
Level 12 : Exp 81%
PD: 0.064
กระทู้: 254
« ตอบ #2 เมื่อ: 11 พฤศจิกายน 2552, 11:40:17 »
มีวิธีลงบ้างมั้ยครับ
sirisak^
คะแนนขอบคุณ: 66
Member ID : 4756
Time Online : 11:21:0
Level 12 : Exp 5%
PD: 0.057
กระทู้: 222
« ตอบ #3 เมื่อ: 16 มกราคม 2553, 11:06:00 »
