22 กุมภาพันธ์ 2562, 20:28:57
ผู้เขียน หัวข้อ:  Phoenix_Service_Software_2009_34_10_40495  (อ่าน 2356 ครั้ง)
FixPhoneLamnarai^
..:::Support File By Wintrsla2003:::..
คะแนนขอบคุณ: 8152
Member ID : 5281
Time Online : 108:14:30
Level 52 : Exp 67%
PD: 1.032
กระทู้: 4197
Firefox 3.5.5
« เมื่อ: 12 ธันวาคม 2552, 11:57:05 »
This Phoenix Service Software installation package includes following SW
components:
- Phoenix Service Software 2009.34.10.40495
- DK2 Dongle Driver v 7.14.0.25
- Nokia Connectivity Cable USB Driver v 7.1.17.0 (for Win2000 driver
version 6.85.15.0)
- Flash Update Package 09.044.022
- FLS-x Dongle Driver v 2.09.28
- FPS-11 version 5.10.0
Error corrections & changes:
- Corrections & changes to DCT-4 IMEI / ESN rebuild procedure
- Please note that depending on what has been replaced, JBV-1 needs
power supply from different sources.
- This is required, because depending on the case JBV-1 needs to set
phone in different operating modes
- Supply power to JBV-1 Docking station from FPS-10 or FPS-21 Flash
Prommer output or external power supply depending on what components
were replaced, see table above.
- Connect phone and scan product, read phone information to check
communication with phone
- Open ôToolsö û ôIMEI / ESN Rebuild DCT-4ö - Menu
- Provide Tucson Password and PIN code which have been delivered to you
by email. Please note that characters are case sensitive
- Select ôUEM Replacedö if needed, see table above.
- Please note that SW update must be done separately, it can not be
combined with this procedure
Known errors & limitations:
- Software downgrade with Tucson system is only possible for BB 5.0
products supporting the Data Package 2 concept.
- Flashing with Flashing with FLS-5, SS-46 and product specific adapter is
not supported anymore
- If you install old DCT-4 data packages, Flash Update Package File
installation path may be wrong. This is caused by very old DCT-4 data
packages which contain Flash Update Package and overwrite current
information during installation. If you experience problems when updating
FPS-x prommers, please check that Phoenix ôPrommer maintenanceö is
looking for the files from the correct location which is ôC:Program
FilesCommon FilesNokiaTssFlashö. If not, Phoenix will show error
ôUpdate via ini û file failedö. In this case, select ôUpdateö from that Phoenix
ôPrommer maintenanceö û UI, browse to correct directory and select
ôfpsxupd.iniö for all other prommers except the FPS-8.
- Multi Flash has limited capabilities, launch Multiflash UI first and then
connect phones one by one, do not attempt to service more than 5
phones at the time
http://rapidshare.com/files/318274362/Phoenix_Service_Software_2009_34_10_40495.exe
ลิงค์หัวข้อ: http://wintesla2003.com/topic/107808
รับงาน ส่งซ่อม Hardware&Software
สอบถามโทร : 080-2619914 (ตั้ม)
ซ่อมไม่ผ่านไม่คิดเงิน
รับปลดล็อค iPhone4/4S/5 3GS 6.x.x LL ราคาพิเศษ
ตู่@ฝาง
NN@mobile ฝาง เชียงใหม่
คะแนนขอบคุณ: 3655
Member ID : 21951
Time Online : 61:6:58
Level 30 : Exp 1%
PD: 0.398
กระทู้: 1364
« ตอบ #1 เมื่อ: 13 ธันวาคม 2552, 14:11:55 »
ขอบคณครับผม
เจ อาร์ โฟน
คะแนนขอบคุณ: 156
Member ID : 23089
Time Online : 7:16:35
Level 10 : Exp 28%
PD: 0.048
กระทู้: 163
« ตอบ #2 เมื่อ: 23 กุมภาพันธ์ 2553, 22:06:47 »
ลูกสาวน่ารักนี้น่ะครับ ท่าน
beephone
@ไม่หล่อ ไม่รวย มีแต่น้ำใจให้ครับ @
คะแนนขอบคุณ: 118
Member ID : 6912
Time Online : 24:14:39
Level 17 : Exp 59%
PD: 0.121
กระทู้: 475
Firefox 3.5.8
« ตอบ #3 เมื่อ: 12 มีนาคม 2553, 23:18:46 »
ขอบคณครับผม
