17 มิถุนายน 2562, 01:25:43
ผู้เขียน หัวข้อ:  Phoenix Service Software 2010.12.008.42304 Cracked [Release Data:2010.04.29]  (อ่าน 6033 ครั้ง)
Mobile_Express^
(aleem)
คะแนนขอบคุณ: 2788
Member ID : 2312
Time Online : 92:16:40
Level 42 : Exp 38%
PD: 0.609
กระทู้: 2719
Firefox 3.6.3
« เมื่อ: 2 พฤษภาคม 2553, 11:59:44 »
Main component versions in the release:
· DK2 Driver Version 07.14.0.25
· Nokia Connectivity Cable USB Driver Version 7.1.27.0
· Flash Update Package 09.050.025
· FLS-x Drivers Version 2.09.28
MAIN CHANGES & ERROR CORRECTIONS FROM PREVIOUS VERSION 2010. 8.4.41526
New Products added
· RM-650, RM-627, RM-648, RM-682
New features
· New Connection manager FUSE replaces old connection manager
Error Corrections & changes
· WCDMA EVM testing issues with Willtek testers corrected, but SW update to Willtek tester is also required.SW must be updated to latest available version Please see http://www.willtek.com/english/nokia for more details
· Ambient Light Sensor Calibration version corrected to version 1_3_0_40303
· New Label Printing DLL to correct font and IMEI length problems
· SW package download capabilities for FiRe / online use enhanced
· MCF Upload correction
· Improvements to decrease finalization delay in flashing related events
· RF Final Test improvements for RM-586
· Minor menu Changes
KNOWN ERRORS & LIMITATIONS
· Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept.
· Flashing with setup FLS-5, SS-46 and product specific adapter is not supported anymore
· If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong.This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix "Prommer maintenance" is looking for the files from the
correct location which is "C:\Program Files\Common Files\Nokia\Tss\Flash". If not, Phoenix will show error "Update via ini – file failed". In this case, select "Update" from that Phoenix "Prommer maintenance" – UI, browse to correct directory and select "fpsxupd.ini" for all other prommers except the FPS-8.
· Some phone models request SIM Lock data to be written in wrong format. You should use special DLL as a workaround for this product software related problem. Please see ASB_MPP_048.pdf"Tucson Add-On Components for SIM Lock versions"
· Refurbishment flashing and product code change for RX-51 product requires SX-4 card to be available
· FPS-21 flashing for RX-51 works only with TCPIP connection. FPS-21 prommer with new HW version is needed to correct this, and it is estimated to be available during 2:nd half of 2010
· Please refer to product specific documents and instructions concerning the limitations of the RX-51 product
· RX-51 flashing does not work when CU-4 is used
· When new version 2010_12_8_42304 with FUSE connection manager is installed on top of older Phoenix versions, there may be an additional delay of several minutes when you start Phoenix for the first time. Please wait patiently; Phoenix will start after configuration is
finished.
· Note concerning the installation and use with Administrator and User rights - If you install Phoenix, start Phoenix and configure connections from FUSE connection manager as Administrator, you may not be able to start Phoenix after you log off and try to use Phoenix with User Rights afterwards
· If you experience the above mentioned problem:
- Log on as Administrator
- Deleted Fuse folder and its contents from: C:\Documents and Settings\All Users\Application Data\Nokia\
- After this Fuse’s connection list will be empty and it can be used directly with guest/admin rights.
- This has to be done only once.
· After you close Phoenix, it may not restart. To rectify this:
- Use Windows Task Manager to manually shut down phoenix.exe and FuseService.exe processes, or optionally restart your PC.
Download link:
RapidShare
or
Torrent
or
4shared.com
ลิงค์หัวข้อ: http://wintesla2003.com/topic/121603
ความรู้ของท่านไม่ได้เสียหาย แจกจ่ายให้สักนิดอุทิศเพื่อส่วนรวม * ไม่มีลิขสิทธิ์ในผลงานที่ข้าพเจ้าได้สรรค์สร้าง เชิญท่านนำไปสร้างสรรค์อย่าได้เกรงใจ *
  0828267982 /+60199966603
ส่งมาที่ร้านกามาโฟนเซอร์วิส เลขที่ 24 ถนน.ทรายทอง 5 อ.สุไหงโกลก จ.นราธิวาส 96120   color]
ตู่@ฝาง
NN@mobile ฝาง เชียงใหม่
คะแนนขอบคุณ: 3655
Member ID : 21951
Time Online : 61:6:58
Level 30 : Exp 1%
PD: 0.385
กระทู้: 1364
« ตอบ #1 เมื่อ: 2 พฤษภาคม 2553, 17:14:34 »
อยากขอบคุณสักพันครั้ง
กำลังอยากได้เลยครับ
เอที โมบาย
NT@Mobile Phrae
คะแนนขอบคุณ: 370
Member ID : 372
Time Online : 35:16:50
Level 24 : Exp 38%
PD: 0.193
กระทู้: 905
Firefox 3.6.3
« ตอบ #2 เมื่อ: 2 พฤษภาคม 2553, 17:25:59 »
ขอบคุณมากๆครับผม
Wintesla2003 Club Detial : http://www.wintesla2003.com/club/239
NOOM_CM
Member ID : 2701
Time Online : 3:8:44
Level 3 : Exp 82%
PD: 0.005
กระทู้: 23
« ตอบ #3 เมื่อ: 20 พฤษภาคม 2553, 11:16:38 »
marmzaza
ความรักคือการให้
คะแนนขอบคุณ: 501
Member ID : 19439
Time Online : 79:23:45
Level 21 : Exp 65%
PD: 0.199
กระทู้: 717
« ตอบ #4 เมื่อ: 20 พฤษภาคม 2553, 13:14:09 »
somkiat malee   081-9390567
สาโรจน์วิทยุการไฟฟ้า 942 ม.2 ถ.สุขาภิบาล2
ต.ในเมือง อ.บ้านไผ่ จ.ขอนแก่น  40110
http://www.wintesla2003.com/club/1070
jazz...
คะแนนขอบคุณ: 1298
Member ID : 20699
Time Online : 48:3:32
Level 26 : Exp 70%
PD: 0.304
กระทู้: 1087
Firefox 3.6.3
« ตอบ #5 เมื่อ: 8 มิถุนายน 2553, 09:30:48 »
คุณจ่ามือถือ
fogusmobile
คะแนนขอบคุณ: 540
Member ID : 29260
Time Online : 60:13:45
Level 17 : Exp 87%
PD: 0.146
กระทู้: 491
« ตอบ #6 เมื่อ: 8 มิถุนายน 2553, 10:04:24 »
ช่างจำเป็น
คะแนนขอบคุณ: 90
Member ID : 1981
Time Online : 20:11:56
Level 26 : Exp 54%
PD: 0.238
กระทู้: 1073
Firefox 3.6.3
« ตอบ #7 เมื่อ: 16 มิถุนายน 2553, 08:41:17 »
pu_Smile
คะแนนขอบคุณ: 18
Member ID : 30448
Time Online : 23:8:2
Level 3 : Exp 74%
PD: 0.007
กระทู้: 22
Firefox 3.6.8
« ตอบ #8 เมื่อ: 21 สิงหาคม 2553, 11:22:01 »
I'am มึนตึ๊บ
Member ID : 30420
Time Online : 12:26
Level 1 : Exp 72%
กระทู้: 4
« ตอบ #9 เมื่อ: 27 สิงหาคม 2553, 12:42:51 »
ღ_d_KIM_b_ღ
รับซ่อมโทรศัพท์ ทุกรุ่น ทุกยี่ห้อ และจำหน่าย โทรศัพท์ NEX มือ 1 ทั้งปลีกและส่ง
ความรู้ไม่มีที่สิ้นสุด อย่าหยุดอยู่กับคำว่า ไม่รู้
คะแนนขอบคุณ: 100
Member ID : 27537
Time Online : 1:12:5
Level 9 : Exp 16%
PD: 0.038
กระทู้: 129
Firefox 3.6.8
« ตอบ #10 เมื่อ: 30 สิงหาคม 2553, 17:39:21 »
 thank you thank you
Justinz
คะแนนขอบคุณ: 59
Member ID : 30719
Time Online : 3:22:22
Level 9 : Exp 59%
PD: 0.043
กระทู้: 143
Firefox 3.6.9
« ตอบ #11 เมื่อ: 15 กันยายน 2553, 15:31:51 »
ขอบคุณครับพี่ ดีครับคุณท่าน ^ ^
ฉัตรณรงค์
คะแนนขอบคุณ: 30
Member ID : 36032
Time Online : 8:5:18
Level 3 : Exp 41%
PD: 0.006
กระทู้: 18
Chrome 7.0.517.41
« ตอบ #12 เมื่อ: 2 พฤศจิกายน 2553, 00:03:28 »
ขอบคุณมากครับ
ยังใช้ไม่เป็นขอเก็บไว้ก่อน
