19 กุมภาพันธ์ 2562, 04:50:08
ผู้เขียน หัวข้อ:  Phoenix Service Software 2010.12.11.42838 Cracked[Release Data:2010.06.17]  (อ่าน 7982 ครั้ง)
FixPhoneLamnarai^
..:::Support File By Wintrsla2003:::..
คะแนนขอบคุณ: 8152
Member ID : 5281
Time Online : 108:14:30
Level 52 : Exp 67%
PD: 1.033
กระทู้: 4197
Firefox 3.6.3
« เมื่อ: 17 มิถุนายน 2553, 12:07:02 »
hello,the latest phoenix,cracked
อ้างถึง
1. Change history 4.6.2010 Initial version
Main component versions in the release:
▪ DK2 Driver Version 07.14.0.25
▪ Nokia Connectivity Cable USB Driver Version 7.1.27.0
▪ Flash Update Package 09.050.025
▪ FLS-x Drivers Version 2.09.28
Please note:
▪ This version contains the latest Tucson components. Therefore it is not necessary to use Tucson Add-On Installation Package v.2010_10_9_41709.
2. Main changes & error corrections from previous version 2010. 12.8.42304
New Products added :
▪ RH-125
New features :
▪ New rf_losses.ini file for RF auto tuning
▪ Support for RH-125 product enabled, Drivers for RH-125 adapter added to installation package
▪ DCT-4 Product code changes can now be done for RH-125.
- Use EXTERNAL Smart Card Reader for SX-4 or 4T, follow reader specific instructions
- Install Phoenix with included Prolific drivers ( you many need to reboot PC during process)
- Install the latest RH-125 Data Package(s)
- Connect CA-101 USB Cable to PC USB Port, and SF-204 adapter to USB Cable
- Allow Windows to install drivers for SF-204 adapter
- Start Phoenix
- Configure connection from FUSE Connection Manager by using following Settings:
- Connection Type: FBUS
- Communication Port Type: USB-COM ( Please scan FBUS Devices from FUSE)
- Connect RH-125 product to SF-204 adapter, check that FUSE detects RH-125 product in connection (select correct connection from "Connections" - dropdown)
- Scan product from "File / Scan Product" - menu , or press CTRL+R
- Select "Product Code Change DCT-4" from "Tools" - menu
- The rest of the process is normal DCT-4 Product Code Change.
- NOTE: Do NOT select "Flash" - option, always perform product code change without flashing the phone when using Phoenix for RH-125.
- NOTE: After Product Code Change, flash the latest SW version matching new product code by using Nokia Care Suite. Phoenix should only be used for product code changes concerning SIM Locked variants. All other service activities for RH-125 should be done by using Nokia Care Suite
Error Corrections & changes
▪ Tucson improvements for RM-614,
▪ Use of separate Tucson add on installation package is not required with this Phoenix release
3. Known errors & limitations
▪ Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept.
▪ Flashing with setup FLS-5, SS-46 and product specific adapter is not supported anymore
▪ If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong. This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix "Prommer maintenance" is looking for the files from the correct location which is "C:\Program Files\Common Files\Nokia\Tss\Flash". If not, Phoenix will show error "Update via ini - file failed". In this case, select "Update" from that Phoenix "Prommer maintenance" - UI, browse to correct directory and select "fpsxupd.ini" for all other prommers except the FPS-8.
▪ Some phone models request SIM Lock data to be written in wrong format. You should use special DLL as a workaround for this product software related problem. Please see Service SW Application document "Tucson Add-On Components for SIM Lock versions"
▪ Refurbishment flashing and product code change for RX-51 product requires SX-4 card to be available
▪ FPS-21 flashing for RX-51 works only with TCPIP connection. FPS-21 prommer with new HW version is needed to correct this, and it is estimated to be available by the end of 2010
▪ Please refer to product specific documents and instructions concerning the limitations of the RX-51 product
▪ RX-51 flashing does not work when CU-4 is used
▪ When new version 2010_12_8_42304 with FUSE connection manager is installed on top of older Phoenix versions, there may be an additional delay of several minutes when you start Phoenix for the first time. Please wait patiently; Phoenix will start after configuration is finished.
▪ When using Data Package download functions with online connection, download times may occasionally be long. This is not caused by Phoenix (or Care Suite). The download speed from online servers is occasionally is known to be slow, depending on how data is buffered on caching servers.
▪ Note concerning the installation and use with Administrator and User rights
- If you install Phoenix, start Phoenix and configure connections from FUSE connection manager as Administrator, you may not be able to start Phoenix after you log off and try to use Phoenix with User Rights afterwards
▪ If you experience the above mentioned problem:- Log on as Administrator
- Deleted Fuse folder and its contents from: C:\Documents and Settings\All Users\Application Data\Nokia\
- After this Fuse's connection list will be empty and it can be used directly with guest/admin rights.
- This has to be done only once.
▪ After you close Phoenix, it may not restart. To rectify this:
- Use Windows Task Manager to manually shut down phoenix.exe and FuseService.exe processes, or optionally restart your PC
Supported operating systems and user rights
▪ Windows XP Service Pack 1 or higher
▪ When installing Phoenix into Win XP you must have local admin rights.
▪ When using in Win XP, user must have power user rights.
อ้างถึง
File:Phoenix Service Software 2010.12.11.42838 Cracked.rar
MD5:C3F75FD4BE9399CECCD354D892171838
SHA1:858421F41A2A7A6CA32DEFF9DFD4EA0BB02E1BC3
http://rapidshare.com/files/399794066/Phoenix_Service_Software_2010.12.11.42838_Cracked.rar
ลิงค์หัวข้อ: http://wintesla2003.com/topic/125501
รับงาน ส่งซ่อม Hardware&Software
สอบถามโทร : 080-2619914 (ตั้ม)
ซ่อมไม่ผ่านไม่คิดเงิน
รับปลดล็อค iPhone4/4S/5 3GS 6.x.x LL ราคาพิเศษ
ตู่@ฝาง
NN@mobile ฝาง เชียงใหม่
คะแนนขอบคุณ: 3655
Member ID : 21951
Time Online : 61:6:58
Level 30 : Exp 1%
PD: 0.398
กระทู้: 1364
« ตอบ #1 เมื่อ: 17 มิถุนายน 2553, 16:38:40 »
 adore adore
watchayun
คะแนนขอบคุณ: 32
Member ID : 499
Time Online : 22:6:25
Level 16 : Exp 25%
PD: 0.089
กระทู้: 404
Linux (Ubuntu)
Firefox 3.0.10
« ตอบ #2 เมื่อ: 7 กรกฎาคม 2553, 08:29:34 »
ขอบคูณครับ
JSS
Member ID : 34078
Time Online : 31
Firefox 4.0b3
« ตอบ #3 เมื่อ: 18 สิงหาคม 2553, 11:30:59 »
ღ_d_KIM_b_ღ
รับซ่อมโทรศัพท์ ทุกรุ่น ทุกยี่ห้อ และจำหน่าย โทรศัพท์ NEX มือ 1 ทั้งปลีกและส่ง
ความรู้ไม่มีที่สิ้นสุด อย่าหยุดอยู่กับคำว่า ไม่รู้
คะแนนขอบคุณ: 100
Member ID : 27537
Time Online : 1:12:5
Level 9 : Exp 16%
PD: 0.039
กระทู้: 129
Firefox 3.6.8
« ตอบ #4 เมื่อ: 30 สิงหาคม 2553, 17:57:02 »
wichai2
คะแนนขอบคุณ: 33
Member ID : 7730
Time Online : 1:23:49
Level 9 : Exp 56%
PD: 0.037
กระทู้: 142
« ตอบ #5 เมื่อ: 11 พฤศจิกายน 2553, 20:56:51 »
inyard
คะแนนขอบคุณ: 113
Member ID : 36540
Time Online : 57:18:33
Level 9 : Exp 50%
PD: 0.046
กระทู้: 140
Firefox 3.6.12
« ตอบ #6 เมื่อ: 13 พฤศจิกายน 2553, 07:51:10 »
ขอบคุณคับ
**พล**
คะแนนขอบคุณ: 120
คะแนนซื้อ-ขาย: (-2)
Member ID : 8442
Time Online : 6:17:14
Level 13 : Exp 35%
PD: 0.072
กระทู้: 274
« ตอบ #7 เมื่อ: 13 พฤศจิกายน 2553, 09:22:25 »
ขอบคุณคับ
**พล**
คะแนนขอบคุณ: 120
คะแนนซื้อ-ขาย: (-2)
Member ID : 8442
Level 13 : Exp 35%
PD: 0.072
กระทู้: 274
« ตอบ #8 เมื่อ: 13 พฤศจิกายน 2553, 09:24:00 »
ผมโหลดไม่ได้คับ
TC Telecom^
คะแนนขอบคุณ: 13
Member ID : 4138
Time Online : 9:10:4
Level 3 : Exp 90%
PD: 0.006
กระทู้: 24
« ตอบ #9 เมื่อ: 10 ธันวาคม 2553, 16:15:28 »
ตุ๋ย
คะแนนขอบคุณ: 9
Member ID : 40464
Time Online : 1:7:52
Level 2 : Exp 11%
กระทู้: 6
« ตอบ #10 เมื่อ: 4 พฤษภาคม 2554, 15:05:06 »
koooo^
Member ID : 1804
Time Online : 20:9:15
Level 9 : Exp 28%
PD: 0.030
กระทู้: 133
Firefox 3.5.3
« ตอบ #11 เมื่อ: 4 มิถุนายน 2554, 21:15:10 »
ขอบคุณมากๆเลยครับ
