20 มกราคม 2563, 15:29:13
ผู้เขียน หัวข้อ:  ไปเจออันนี้มาก็เลยเอาฝาก ปลดล็อค LG  (อ่าน 8142 ครั้ง)
MJMobile@samui
มิตรภาพที่ดีมาจากข้างใน
คะแนนขอบคุณ: 2133
คะแนนซื้อ-ขาย: (-1)
Member ID : 11318
Time Online : 209:20:29
Level 29 : Exp 80%
PD: 0.333
กระทู้: 1353
« เมื่อ: 17 พฤษภาคม 2554, 11:34:28 »
Model: LG C2000
1. Insert an unauthorized Sim Card and turn ON your phone
2. The phone will display "Phone Restricted"
3. Select "Cancel"
4. The phone will display "Phone Restriction Code"
5. Enter Unlock Code
6. Select OK
7. The handset is now successfully unlocked
Obtain the unlocking code from @ Theunlock.ca - Worldwide Mobile Phone Unlocking
Model : LG Prime GS390
1. Power phone ON without SIM
2. Type 2945#*290# to enter unlock menu
3. Enter unlock code
Or
With original sim enter *#865625# and enter NCK code.
Model : LG KH5200 Andro-1
1. Power on the LG KH5200 Andro-1 with the not accepted SIM card in.
2. Enter 2945#*5200#
3. A menu will pop up to enter code provided.
4. Enter your unlock code and hit OK.
5. The LG KH5200 Andro-1 is now unlocked
Model : LG GB130
1. Without sim type: *#9999#
2. Type: 2945#*20001#
3. Goto Menu->Setting->Secutiry->Sim Locked->Sim Unlock Code
Model : LG KM570
2. Type 2945#*570# to enter unlock menu
Or
Model : LG KP170
1 - Switch ON your phone with a T Mobile Sim inserted
2 - Press telephone icon at bottom of screen to bring up the phone keypad
3 - Then compose : 2945#*170#
4 - A menu will pop up, select Unlock Usim
5 - Then Select Network Lock
6 - Enter your unlock code and press ok (you only have 10 attempts)
7 - The phone will then reboot and the unlock is complete.
LG GM360 Viewty Unlocking Instructions
1. Power on your LG Viewty GM360 with the original SIM card in.
2. Enter 2945#*700#
3. A menu will pop up, select SIM Unlock.
4. Enter your unlock code and hit OK. (Entering multiple incorrect unlock codes may permanently lock your phone!)
5. Your LG Viewty GW300 may automatically reboot and should now be unlocked!
LG GU285 Unlocking Instructions
1. Insert original sim card and turn phone on.
2. Enter 2945#*280#
3. Sim unlock mode pop up .
4. Enter your unlock code: , and press ok
5. The phone will then reboot and the unlock is complete.
LG GT360
2. Enter 2945#*71001#
Model: LG GT400
1. Turn phone on without simcard
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*400#
4. A menu will pop up, select network unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete
Model: LG GT405
3. Enter 2945#*405#
Model : LG GB220
1.- Power phone ON without SIM
2.- type 2945#*71001# to enter unlock menu
3.- enter unlock code
Model : LG GM205
1. Power phone ON with original SIM
2. type 2945#*71001# to enter unlock menu
3. Enter the unlocking code
Model : LG TU750 Secret:
2. Enter *#865625#
3. A menu will pop up, select USIM unlock
4. Select Network lock
6. Enter the unlock code again
Model : LG GD880 mini
1. insert an ACCEPTED (it means from the Provider, in my case it was A1) SIM-Card
2. dial 2945#*880# (...a page will appear for entering the unlock-Code)
3. enter the unlock-Code and press "ok" 4. enter the same unlock-Code again and press "ok" > your gd880 mini is unlocked, you can enter now the restricted SIM-Card and it will work.
Model LG LG BL40 Chocolate
1. insert original sim card or motorola test card and turn phone on.
2. Enter 2945#*40#
3. A menu will pop up, select sim unlock
4. Enter your unlock code and press ok
Model LG GW520
1. power phone ON with original SIM
Model LG CE110
2. The phone display Invalid Smart Chip?
3. Select "Cancel"
4. The phone displays "Phone Restriction Code"
6. Select OK
7. The phone may reboot and the unlock is completed
Model LG GD510 Pop
1. Power phone ON without SIM (some versions will need original network
sim inside)
2. Type 2945#*510# to enter unlock menu. Select the 'network Unlock' option.
Model LG CF360
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock instructions LG GW620 Eve
Â
1. Insert an invalid simcard and turn phone on.
2. Insert PIN
3. Phone says "Invalid sim card"
4. Select "Emergency calls"
5. Enter 2945#*620#
6. Sim unlock mode pop up
7. Select netlock
8. Enter your 16-digit unlock code and press ok
9. The phone will then reboot and the unlock is complete.
Model: LG TU500
- Insert the SIM card to the phone’s slot
- Switch on the power of handset.
- You must see the message appears ‘Invalid SmartChip’. If you can see that message display in your phones, what you need is switch off the power of your phone and back it on again. Repeat this step until the message appears.
- Now in idle screen enter 159753#*#.
- On the phone appears “Enter NCK, Remaining 5”
- Enter 6 digits SIM unlock code you’ve got.
Model: LG CU400 & CU500v
3. In Idle screen, enter 159753#*#
4. Phone will display "Enter NCK, Remaining 5"
6. Select OK
Model: LG CU575 Trax
1. Insert an authorized Sim Card and turn ON your phone
2. Enter *#865625#
3. Select 1 and then 1 again
4. Enter Unlock Code
5. Press OK
6. The phone may reboot and the unlock is completed�
Model: LG TG365 Neon
2. Enter *#865625#
3. Select Yes
5. Enter Unlock Code again.
6. Press OK
Model: LG CU720, TU720 & ALL LG Shine Series
2. Enter *#865625#
3. Enter Unlock Code
4. Press OK
5. The phone may reboot and the unlock is completed
Model: LG Vu CU915 & CU920
2. Enter *#865625#
3. Sim unlock mode will open up
5. Press OK
6. Device should say Network Lock Deactivated?
7. Phone may automatically reboot and is now unlocked
Model: LG CT810 Incite 1. Insert an authorized Sim Card and turn ON your phone
2. Enter 2945#*810#
3. A Menu will open up
4. Select Sim unlock
6. Press OK
7. The phone will reboot and the unlock is completed
Model: LG KC550, KF600, KP230, KP500, KP501, KP270, KS360
5. Press OK
6. The phone will reboot and the unlock is completed
Model: LG GT505
2. Enter 2945#*500#
3. Select Unlock USIM
4. Select Network Lock
6. Select OK
Model: LG GR500 Xenon
2. Enter *#865625#
5. Press OK
Model: LG KC910, KF910 (aka LG *****)
2. Enter 2945#*910#
5. Press OK
Model: LG KE850 *****
2. Enter Sim PIN if required
3. Enter 2945#*8501# and press the call button (middle button, bottom of the screen)
4. SIM unlock mode will appear on screen
6. Select Reboot
7. Turn phone OFF, and then turn back ON again. Phone is now unlocked
Model: LG KE990 & KU990 Viewty
3. Enter 2945#*990#
4. Sim unlock mode will open up
6. Press OK
Model: LG KF390 & KF390q
2. Enter *#865625#
6. Select OK
Model: LG KF700 (aka LG Virgo)
2. Enter 2945#*700#
5. Press OK
Model: LG KF750
2. Enter 2945#*750#
5. Press OK
Model: LG KP265
1. Insert an authorized Sim Card and turn ON the phone
2. Enter 2945#*265#
3. Menu will appear
4. Select Settings
5. Select Security
6. Select Sim Lock
7. Select Network
8. Select Deactivate
9. Enter Unlock Code
Model: LG ME550
2. Enter 2945#*71101#
3. Menu will appear
4. Select Settings
5. Select Security
6. Select Sim Lock
7. Enter Unlock Code
8. Press OK
Model: LG TU915 (Unlock Method 1)
2. Enter 2945#*9701#
5. Press OK
Model: LG TU915 (Unlock Method 2)
2. Enter *#865625#
5. Press OK
6. The phone will reboot and the unlock is completed�
Model: LG U300
2. Enter 815118#*#
5. Press OK
Model: �LG U310
1. Turn ON the phone without Sim Card
2. Enter 815118#*#
5. Press OK
Model: �LG U400
2. Enter 2945#*88110#
3. Phone will prompt ��Unlock Sim�?
4. Press OK
5. Phone will prompt ��Network Unlock�?
6. Press OK
7. Phone will prompt ��Input Network Control Key�?
8. Enter Unlock Code (If the unlocking code comes with only 7 digits, add 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digits code)
9. Press OK
10. The phone may reboot and the unlock is completed�
Model: �LG U970
2. Enter 2945#*970#
5. Press OK
Model: �LG U8150
2. Enter�277634#*#
3. Select Menu then "SIM Lock"
4. Enter Unlock Code�
Model: �ALL other model
2. Enter:
LG 510W: Enter 2945#*5101#
LG 1200 & B1200: Enter 1945#*5101#
LG 5200 & 52200: Enter 2945#*5221#
LG 5300: Enter 2945#*5301#
LG 5400: Enter 2945#*5401#
LG 7020: Enter 2945#*70001#
LG 7100: Enter 2945#*7101#
LG 1100: Enter 2945#*1201# or 2945#*70001#
LG 7250T: Enter 2945#*70001#
LG C2200: Enter 2945#*2201#
LG T5100: Enter 2945#*5301#
LG C3310: Enter 2945#*3311#
3. Select Menu
4. Select Settings
5. Select Security
6. Select Network Provider
7. Select Deactivate
8. Enter Unlock Code�
Model: �Classified by Model
2. Enter:
LG C3100: Enter 2945#*3101#
LG C3380: Enter 2945#*7101#
LG F2300: Enter 2945#*7101#
LG KE260: Enter 2945#*2601#
LG KE970: Enter 2945#*9701#
LG KG120: Enter 2945#*1201#
LG KG220: Enter 2945#*1201#
LG KG240: Enter 2945#*3311#
LG KG280: Enter 2945#*7101#
LG KG290: Enter 2945#*7101#
LG KG800: Enter 2945#*7101#
LG KU250: Enter 2945#*250#
LG KU380: Enter 2945#*380#
3. Select Menu
4. Select Settings
5. Select Security
6. Select Sim Lock
8. Press OK
9. The phone may reboot and the unlock is completed�
2. Enter:
LG KU311: Enter 815118#*#
LG KU800: Enter 82652#*#
LG L600v: Enter 815118#*#
LG U8150: Enter 277634#*#
LG U8210: Enter 277634#*#
LG U8500: Enter 277634#*#
LG U400: Enter 2945#*88110#
LG KC550: Enter 2945#*71001#
LG KU580: Enter 2945#*580#
LG KT520: Enter 2945#*520#
LG KF750: Enter 2945#*750#
LG KF600: Enter 2945#*71001#
LG KG275: Enter 2945#*20001#
LG KS500: Enter 2945#*500#
LG KP270: Enter 2945#*270#
LG KF240: Enter 2945#*240# or 2945#*2401#
4. Press OK
enter code LG 320G
2. Enter 277634#*#
4. Enter Unlock Codeï
CREDIT :http://www.gsmthai-forum.com
ลิงค์หัวข้อ: http://wintesla2003.com/topic/152782
http://wintesla2003.com/club/540เลขที่บัญชี 8272091712 ธวัลรัตน์ คำแก้ว ธนาคารไทยพาณิชย์  สาขา แม่น้ำ
ที่อยู่ ชิษณุพงศ์ วิวัฒนาชัยกุล 3/8 หมู่ 6 ต.บ่อผุด อำเภอเกาะสมุย จังหวัดสุราษฎร์ธานี 84320 โทร 0870007368
<“•’’_O_Map_“•’’>
Member ID : 11107
Time Online : 6:22:44
Level 6 : Exp 5%
PD: 0.014
กระทู้: 56
Chrome 11.0.696.68
« ตอบ #1 เมื่อ: 23 พฤษภาคม 2554, 11:29:43 »
1  * nop9
nop9
คะแนนขอบคุณ: 2333
Member ID : 13095
Time Online : 71:7:27
Level 26 : Exp 55%
PD: 0.268
กระทู้: 1074
Chrome 10.0.648.205
« ตอบ #2 เมื่อ: 23 พฤษภาคม 2554, 12:04:07 »
phuipui
ทำวันนี้ให้ดีที่สุด
คะแนนขอบคุณ: 421
Member ID : 16499
Time Online : 41:6:16
Level 21 : Exp 61%
PD: 0.183
กระทู้: 714
« ตอบ #3 เมื่อ: 23 พฤษภาคม 2554, 12:06:36 »
easy777
ทำวันนี้ให้ดีที่สุด
คะแนนขอบคุณ: 87
Member ID : 2471
Time Online : 10:23:23
Level 16 : Exp 9%
PD: 0.085
กระทู้: 395
Chrome 11.0.696.68
« ตอบ #4 เมื่อ: 23 พฤษภาคม 2554, 12:20:11 »
ยินดี กับ การตอบรับ ของสมาชิกทุกทานนะครับ
saravit
อย่าโทษโชคชะตาเกิดมาไม่เหมือนกันที่สำคัญคือความคิด
คะแนนขอบคุณ: 12
Member ID : 26853
Time Online : 3:11:32
Level 4 : Exp 71%
PD: 0.010
กระทู้: 35
Chrome 12.0.742.122
« ตอบ #5 เมื่อ: 13 กรกฎาคม 2554, 16:48:20 »
สุดยอดครับ
เก๋ โมบาย
คะแนนขอบคุณ: 265
Member ID : 41306
Time Online : 37:3:35
Level 12 : Exp 19%
PD: 0.073
กระทู้: 228
« ตอบ #6 เมื่อ: 13 กรกฎาคม 2554, 17:17:30 »
jakkritpop
Member ID : 8716
Time Online : 1:8:27
Level 5 : Exp 21%
PD: 0.010
กระทู้: 42
« ตอบ #7 เมื่อ: 18 กุมภาพันธ์ 2555, 16:46:05 »
thk you
แอบ-3339
คะแนนขอบคุณ: 68
Member ID : 6363
Time Online : 60:14:45
Level 16 : Exp 4%
PD: 0.091
กระทู้: 392
Chrome 49.0.2623.112
« ตอบ #8 เมื่อ: 11 มิถุนายน 2562, 13:18:40 »
 best3
