21 พฤษภาคม 2562, 16:42:53
ผู้เขียน หัวข้อ:  Phoenix Service Software 2012.36.001.48629 สำหรับใช้โหลดไฟล์แฟลช Nokia  (อ่าน 14055 ครั้ง)
Omap K-boxteamthailand®
n-unlock thailand
คะแนนขอบคุณ: 3396
Member ID : 11122
Time Online : 55:15:27
Level 27 : Exp 29%
PD: 0.295
กระทู้: 1132
Firefox 21.0
« เมื่อ: 28 พฤษภาคม 2556, 16:48:50 »
Main component versions in the release:
• Product API 2012.31.2
• Nokia Connectivity Cable USB Driver Version 7.1.78.0
• Flash Update Package 2012.30.1
• FUSE Connection Manager v 2012.27.4
MAIN CHANGES & ERROR CORRECTIONS FROM PREVIOUS VERSION 2012.24.0.48366
Error Corrections & changes:
New products: RM-908, RM-909, RM-872, RM-873, RM-874, RM-907
Please note:
IMPORTANT!
Phoenix installation requires a network connection if DOT.NET framework 4.0 is not installed on PC
(.NET framework is downloaded from web during phoenix installation).
New common data package location in use. Please see document SR1315 in KICS Information Center for further information.
All Nokia Service Software Applications will use following location for product specific data:
- Windows XP: C:\Documents and Settings\All Users\Application Data\Nokia\Packages
- Windows 7: C:\Program Data\Nokia\Packages
Please see articles SR1774 for more information on the use of Nokia Data Package manager – tool, and article SR1854 for more information on the Nokia Service Application Manager Tool.
During installation, Data Packages should be installed in these directories, if they install to any other location by default. Target folder for local data packages can be changed in the installation wizard manually.
This version contains the latest Tucson components. Therefore it is not necessary to use Tucson Add-On Installation Packages.
Before you start Phoenix or Care Suite installation to Windows 7 the User Account Control (UAC) should be turned off from Windows Control Panel settings.
For more information concerning new options in “Firmware Update” – menu and their use, Please see documents SR1313 and SR1659 in KICS Information Center.
Tucson operations combined with “flash” – option are now handled in the same way as “refurbishment”, which requires Mass Memory Content File to be available.
Use of Flash option simultaneously with product code change for USB Only phones is restricted. It is recommended to flash phone separately with Firmware Update. Please refer to product specific instructions.
Connection media to FLS-5 must be configured to be “USB_FBUS”, after FLS-4 support has been removed FBUS does not work anymore with FLS-5
KNOWN ERRORS & LIMITATIONS
Energy Management Calibration should not be performed for products using the “Quantum” engine (RM-689, RM-702, RM-704 and other product using the same engine)
• N9- RM-696 Product Code change still unreliable
• Nokia 500 RM-750 Refurbish may occasionally fail.
• Product code change is not working with RM-838, RM-852, RM-843. Please use Product identity tool (SR2872)
• FLS-5 drivers do not support 64 bit OS, so phones using FLS-5 /USB_FBUS connection can not be serviced in 64 bit operating systems
• Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept.
• Flashing with setup FLS-5, SS-46 and product specific adapter is not supported anymore. FLS-5 can be used with other product specific cables and adapters, but not with SS-46 Interface Adapter.
• If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong. This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8.
• FPS-21 flashing for RX-51 works only with TCPIP connection. FPS-21 prommer with new HW version 11 has been released to correct this. Sales pack code is 0089J83 , old HW version is not delivered anymore
• Please refer to product specific documents and instructions concerning the limitations of the RX-51 product
• When version 2010_12_8_42304 or newer with FUSE connection manager is installed on top of older Phoenix versions, there may be an additional delay of several minutes when you start Phoenix for the first time. Please wait patiently; Phoenix will start after configuration is finished.
• When using Data Package download functions with online connection, download times may occasionally be long. This is not caused by Phoenix (or Care Suite). The download speed from online servers is occasionally is known to be slow, depending on how data is buffered on caching servers.
• After you close Phoenix, it may not restart. To rectify this:
- Use Windows Task Manager to manually shut down phoenix.exe and FuseService.exe processes, or optionally restart your PC
• It is not possible to program Mass Media Content file to some devices over direct USB cable connection, due to the large size of the file. For these models a feature called “Media Check” has been implemented. When this type of product is connected to service software / PC via direct USB cable the refurbishment option will be disabled. Please use a flash prommer. Affected products using Media Check are: RM-122, RM-175, RM-176, RM-186, RM-246, RM-247, RM-296, RM-297, RM-320, RM-462, RM-472, RM-484, RM-505, RM-555, RM-559
• To be able to use the help files in Windows 7 you need to install Windows Help program (WinHlp32.exe) for Windows 7. Ways to locate WinHlp32.exe:
- Start Phoenix with online connection to Internet, select “Help” and “Phoenix help”. Click the “Microsoft Help and Support” website link. Download WinHlp32 and install it.- Go to Microsoft Home Page | Devices and Services. Type “WinHlp32″ to “Search Microsoft.com” – field. Locate Windows Help program (WinHlp32.exe) for Windows 7 and install it
• When using flash prommers, only one connection type to one prommer is allowed. Please use either NFPD USB or NFPD TCPIP connection to one prommer, not both connections to same prommer
Supported operating systems and user rights
• Windows XP Service Pack 1 or higher
• When installing Phoenix into Win XP you must have local admin rights.
• When using in Win XP, user must have power user rights.
• Windows 7 32 Bit version
• Windows 7 64 Bit version (Please note that FLS-5 drivers do not support Win 7 64 bit OS, therefore FLS-5 can not be used in this operating system)
http://www.4shared.com/rar/KPC3tgO0/Phoenix_Service_Software_20123.html
ลิงค์หัวข้อ: http://wintesla2003.com/topic/209181
สอนให้เขาตกปลา ดีกว่าให้ปลาเขากิน https://www.facebook.com/Nunlockthailand
marmzaza
ความรักคือการให้
คะแนนขอบคุณ: 501
Member ID : 19439
Time Online : 79:23:45
Level 21 : Exp 65%
PD: 0.200
กระทู้: 717
Firefox 21.0
« ตอบ #1 เมื่อ: 29 พฤษภาคม 2556, 08:42:59 »
somkiat malee   081-9390567
สาโรจน์วิทยุการไฟฟ้า 942 ม.2 ถ.สุขาภิบาล2
ต.ในเมือง อ.บ้านไผ่ จ.ขอนแก่น  40110
http://www.wintesla2003.com/club/1070
ท่านเปา
Member ID : 58151
Time Online : 1:1:34
Level 1 : Exp 36%
กระทู้: 2
Microsoft Internet Explorer 10.0
« ตอบ #2 เมื่อ: 24 ตุลาคม 2556, 16:16:37 »
ขอหน่อยครับ
koogkai
คะแนนขอบคุณ: 52
Member ID : 53614
Time Online : 8:5:40
Level 3 : Exp 90%
PD: 0.011
กระทู้: 24
Chrome 32.0.1700.107
« ตอบ #3 เมื่อ: 6 กุมภาพันธ์ 2557, 14:44:26 »
ประชัยศักดิ์
Member ID : 55909
Time Online : 2:14:39
Level 1 : Exp 72%
กระทู้: 4
Firefox 29.0
« ตอบ #4 เมื่อ: 8 เมษายน 2557, 06:33:20 »
Please note:
IMPORTANT!
ใช้แล้วแฟลชไม่จบ เวลาเปิดเครื่องจะมีอาการ ติด ดับ 5ครั้ง เอากล่อง atf เช็คดู พบว่าแฟลชไม่จบ มีวีธีแก้ไข้ใหมครับ อาการหนักขนาดนี้
jamsi
Member ID : 36374
Time Online : 5:12:57
Chrome 34.0.1847.116
« ตอบ #5 เมื่อ: 24 เมษายน 2557, 18:10:22 »
ขอบคุณครับ นึกว่าหาไม่ได้แล้ว
kang2518
Member ID : 5795
Time Online : 9:28
Level 2 : Exp 45%
กระทู้: 9
Chrome 33.0.1750.146
« ตอบ #6 เมื่อ: 25 กรกฎาคม 2557, 18:33:53 »
ขอบคุนครับ
tieradet
คะแนนขอบคุณ: 23
Member ID : 38625
Time Online : 25:10:11
Level 6 : Exp 36%
PD: 0.021
กระทู้: 63
Chrome 40.0.2214.91
« ตอบ #7 เมื่อ: 22 สิงหาคม 2558, 14:03:19 »
ขอบคุนครับ
