19 พฤษภาคม 2562, 22:37:30
ผู้เขียน หัวข้อ:   R-SIM 10 iPhone 6P,6,5S,5C,5,4S Easy Unlocking and Activation SIM  (อ่าน 4441 ครั้ง)
คะแนนขอบคุณ: 30528
PD: 1.590
Firefox 34.0
« เมื่อ: 31 ธันวาคม 2557, 10:12:31 »
Model  R-SIM 10
Condition  New
R SIM 10 iPhone 6,6Plus,5C,5S,  5,4S iOS8.X Unlocking & Activation Works with all SIM cards & Networks 2G/3G/4G GSM/CDMA/WCDMA/LTE.
4G network Signal drop fixed with new Self-Repair Function.No more problem getting back 4G network when you change tower or when you lose network in low Network areas
SPRINT (CDMA) iPhones using 4G SIM cards on 4G Networks bugs fixed with Self-Repair Functions.
MORE INFO
1. 4G Network Signal drop fixed with new Self-Repair Function. No more problem getting back 4G network when you change tower or when you lose network in low Network areas like underground stations & no Network areas
2. SPRINT (CDMA) iPhones using 4G SIM cards on 4G Network bugs fixed with Self-Repair Functions. Activation request pop-up flaw has been fixed when using 4G SIM cards on 4G networks using SPRINT or CDMA iPhones.
3. DUAL mode Function implemented on the menu for 3G only Networks on iOS8.X.. Now more Stable with this function.No more Network drops when you use DUAL mode function on iOS8.X  for people with only 3G Networks.
4. Lock Carrier Function improved. You can now use your iphone as Factory Unlocked with Lock Carrier Function.. First time you use R-SIM 10 it will ask you to select the Network your iPhone is Locked to. Select and then press Lock Carrier button on the menu then use your iPhone as factory Unlock. With Lock Carrier function you will Never see any pop menu again after you power Off and On your iPhone, Battery drained or remove and put simcard. As lond as you are using same SIMcard you will never be asked to so anything anymore, just use like factory unlocked iPhone.
5. iPhone 4S on iOS8.X improved and now very stable. Improved SIM tray added for only iPhone 4S.
6. For iPhone 6P/6/5S/5C/5 use your Original SIM tray that came with your iPhone. R-SIM10 is very Slim sized to fit in your Original iPhone SIM tray. The SIM tray we added on the pack is for 4S only..
https://www.youtube.com/watch?v=_9vJqQQVP8c
ราคาชุดละ  520  บาท (ไม่รวมค่าจัดส่ง)
ราคาขายส่งตั้งแต่ 5 ชุดขึ้นไป กรุณาสอบถาม โทรฯ 0-2622-6560
ลิงค์หัวข้อ: http://wintesla2003.com/topic/228579
