23 มิถุนายน 2561, 13:03:46
ผู้เขียน หัวข้อ:  แจ้งผู้ใช้ Infinity CM2 dongle การ์ดถูก Blocked  (อ่าน 1555 ครั้ง)
smartgsmthai-dl.com
SmartGSM Thai
" มีแล้วไม่ได้ใช้ ดีกว่าจะใช้แล้วไม่มี "
คะแนนขอบคุณ: 3912
Member ID : 2751
Time Online : 51:15:0
Level 44 : Exp 80%
PD: 0.750
กระทู้: 3043
Chrome 53.0.2785.116
« เมื่อ: 26 กันยายน 2559, 13:13:54 »
Problem: Dongle is Blocked.
Reason: It may be a result of software (or drivers) conflicts or other issue.
How to solve:
- Run DongleManager
- Read S/N (Serial Number)
- You will see Error message and Error Code
Error Code #57:
1. Uninstall any kind of usb trace/spy/sharing software and do not use it in future
2. Kill in your PC Device Manager all processes with name like usb3monitor
3. Find in folder with CM2 or [BEST] software file fault.bin
4. Send an e-mail to dongle [at] infinity-box.com with the next information:
4.1. Confirm that 1. and 2. done
4.2. Include in your e-mail your Box/Dongle info
4.3. Attach to your e-mail fault.bin file. If you can not find a file do not attach it.
Error Code #62:
1. Check and clean your PC for viruses
2. Find in folder with CM2 or [BEST] software file fault.bin
3. Send an e-mail to dongle [at] infinity-box.com with the next information:
3.1. Confirm that 1. done
3.2. Include in your e-mail your Box/Dongle info
3.3. Attach to your e-mail fault.bin file. If you can not find a file do not attach it.
Other Error Code:
1. Find in folder with CM2 or [BEST] software file fault.bin
2. Send an e-mail to dongle [at] infinity-box.com with the next information:
2.1. Include in your e-mail your Box/Dongle info
2.2. Attach to your e-mail fault.bin file. If you can not find a file do not attach it.
- DO NOT send us screenshots but only text with explanation and Box/Dongle details are required !
- DO NOT update Box/Dongle with DongleManager without supporter confirmation otherwise Box/Dongle will be locked for a several days after 3 useless tries !
วิธีแก้ปัญหา แปลเป็นไทยแบบง่ายๆ คือ
1.ส่งอีเมล ถึง dongle@infinity-box.com
2.ใส่ข้อมูล SN : ของดองเกิลที่ท่านใช้อยู่
3.แนบไฟล์ fault.bin ที่โปรแกรมสร้างขึ้นมา(ซึ่งจะอยู่ในโพลเดอร์ของโปรแกรมที่เราติดตั้งไว้)
หมายเหตุ : หากไม่มีหรือหาแล้วไม่เจอไฟล์ fault.bin ก็ไม่ต้องแนบไป
4.รออีเมลตอบกลับ
สาเหตุ : ของปัญหาคือ อาจเกิดจากในคอมของท่านมีโปรแกรมที่มีความอันตรายต่อโปรแกรม Infinity Dongle
เช่น FlexiHub ที่ใช้กับการปลดแบบทีมวิวต่างๆ คือไม่ควรติดตั้งค้างไว้ในเครื่องหากมีความจำเป็นต้องใช้ให้ติดตั้งใช้งานเวลาที่ต้องใช้ ใช้แล้วก็ถอนออก
ลิงค์หัวข้อ: http://wintesla2003.com/topic/236491
bigkorat
คะแนนขอบคุณ: 12
Member ID : 20613
Time Online : 1:21:55
Level 5 : Exp 64%
PD: 0.016
กระทู้: 50
Chrome 53.0.2785.143
« ตอบ #1 เมื่อ: 26 ตุลาคม 2559, 13:35:51 »
ขอบคุณครับพี่ เจองานพอดีเลย
