18 กุมภาพันธ์ 2562, 02:02:07
ผู้เขียน หัวข้อ:  Phoenix_Service_Software_2007_44_3_30990 ตัวใหม่ครับ  (อ่าน 2526 ครั้ง)
ยุทธนาปราจีน ซ.บุญปลูก
.:: NokiaOnlineKICS ::.
.:: I-Mobile Support ::..:: LG Support ::.
คะแนนขอบคุณ: 377
Member ID : 223
Time Online : 33:23:40
Level 19 : Exp 61%
PD: 0.128
กระทู้: 589
« เมื่อ: 3 มกราคม 2551, 13:38:02 »
download Phoenix_Service_Software_2007_44_3_30990
Nokia APAC NOL
3 (1)
CONFIDENTIAL
APAC TECHNICAL SUPPORT Create Date
Wilchua 17 December 2007 ASB<MPP>029
MULTI PROTOCOL PHOENIX SERVICE SOFTWARE
2007.44.3.30990
INTRODUCTION
Update version of Phoenix service software is available. This multi-protocol service
software supports Nokia CDMA, GSM, TDMA and WCDMA products. Please see product
specific service bulletins for phone model specific information and instructions.
Service SW installation packages, SB’s, and product specific service bulletins are available
in NOL.
IMPORTANT
If you have Phoenix version 2007.4.6.170 or older you must uninstall it before
installing this release.
If you are installing this version of Phoenix on a new Imaged PC and you are using
an FLS-4S or FLS-5 during the install then install the FLS-X drivers first.
In order to Use FPS-11, you may need to install a separate package, which can be
found in NOL.
This installation package contains the following components:
- Connectivity Cable Driver v 6.85.10.0
- Flash Update 07.46.043, FPS-8 and FPS-10
- FLS-x Drivers v 2.09.17
- DK2 Dongle Driver v 7.14.0.25
Recommended PC HW Requirements:
- Computer Processor: Pentium 700 MHz or higher
- RAM 256 MB
- Needed disk space 100-200 MB
Supported Operating Systems:
- Windows 2000 Service Pack 4 or higher
- Windows XP Service Pack 1 or higher
When installing Phoenix into Win 2000 or XP you must have admin rights locally.
For using the Phoenix in Win 2000 or XP, user must have power user rights.
After installing Phoenix Service Software version, please install the latest product
specific data packages or SW bundles.
Nokia APAC NOL
3 (2)
CONFIDENTIAL
Supported Models
The list of supported models is available once Phoenix is installed by navigating to
the Open Product under the File menu.
Changes in version 2007.44.3.30990 for GSM/WCDMA phones
New features & error corrections:
• New Prommer SW 07.46.043.
• New rf_losses.ini ver.35 added.
• USB flashing is fixed
• IMEI rebuild fixed for some DCT-4 models
• New product add
o 6300I, 6650, 6690, 7070 and 7070b
Known Errors
• FLS-5 is unable to rebuild IMEI/ESN and certificates.
Changes in version 2007.44.3.30990 for CDMA phones
• ESN rebuild with FPS-10 is fixed.
Known Errors
• FPS-11 has limited success with this Phoenix version.
• FPS-11 should not be used to revive “dead” Phones.
• Phoenix does not restore the Theme/Background for 3155i, 3155, 3152, 6155, 6155i,
and 6152 after Easy Flash. See ASB_RM-41_011.pdf (NOL > Support Library >
APAC – Phones > 3155 > General Bulletin) or ASB_RM-59_007.pdf (NOL > Support
Library > APAC – Phones > 6155 > General Bulletin).
Nokia APAC NOL
3 (3)
CONFIDENTIAL
General information
• First time installing Phoenix may take a longer time.
• Auto creation of phone data XML-file is an alternative of the fault-log module, and the
path for saving the XML files can be modified with the new UI under
Tools>Options>Phone Info XML files setting menu.
• Rebuilding IMEI/ESN, SIM lock requires Smart card, SX-4 with rebuild access rights
enabled. Please send your SX-4's serial number to your regional security officer if
you need these rights.
• Rebuilding ESN/IMEI with FPS-8 now requires SX-4 card to be used. An external
smart card reader is needed when using the FPS-8.
• Auto-tuning requires a user registered and activated SX-4 card.
• Changing product codes and restoring certificates in BB-5 products may require the
SX-4 card to be reregistered with your security officer.
• BB5 products cannot generally be flashed using the FPS-8.
• Preferred connection to FPS-10 is using the LAN port.
• The preferred connection to FLS-4S is using the USB port.
• In order to use Willtek 4400 for auto tuning, we recommend updating the Willtek with
a new PC; minimum firmware version of the Willtek 4400 must be ver.12.30. For
further information and required HW options please contact your local Willtek sales
representative or e-mail to mailto:support@willtek.com
• NFPD (Nokia Flash Prommer Device) is the new connection name for FPS-10 and
coming flash prommer connection.
Nokia APAC NOL
3 (4)
CONFIDENTIAL
Assemblies Affected
All GSM, WCDMA, TDMA and CDMA phone models mentioned on page 2 of this
technical bulletin.
Special Equipment:
In order to use Phoenix with phone models supported by it, you need to use
1. Latest Phoenix Service Software 2007.44.3.30990 or newer, includes all needed
drivers and flash support files
2. Latest phone model specific Phoenix Data Package or Flash Bundle
3. Flash Update Package for FPS-10/FPS-8/FLS-4S/FLS-5 (v 06.44.047 included in the
package)
4. JBV-1 Software Update v 18 or newer (See ASB_AST_009.PDF (NOL > Support
Library > APAC – Service Software & Bulletin > Drivers & Bulletin > JBV-1 &
Bulletin); not valid for JBV-1 RoHS compliant)
5. Parallel Port Driver for FPS-8 if you experience slow file transfer speed via LPT port
(See ASB_AST_071.pdf (NOL > Support Library > APAC – Service Software &
Driver > Drivers & Bulletin > FPS-8 General Bulletin))
6. PK-1 or PKD-1 Dongle (PKD-1NS for type label printing) OR FLS-4S/FLS-5 POS
Flash Dongle
7. Programming devices for updating the phone software
8. Phone model specific service tools
• A complete Phoenix service sw installation package always includes the latest
drivers and flash update files available at the time of the release.
• Please use separate driver or flash support file installation packages only if
updates occur between complete Phoenix releases.
For details of installing each package, please refer to phone model specific Service
Manuals and Technical Bulletins concerning each mentioned update package.
Nokia APAC NOL
3 (5)
CONFIDENTIAL
Procedure
How to install new Phoenix 2007.44.3.30990
1. Download phoenix_service_sw_2007.44.3.30990.exe application file to your
computer (e.g. C:\TEMP)
2. Close all other programs
3. Run phoenix_service_sw_2007.44.3.30990.exe and follow instructions on the
screen to install Phoenix Service Software.
4. Connect a dongle (PK-1, PKD-1, FLS-4S, FLS-5) when message appears on the
screen.
5. If you are prompted to update any existing driver or file versions, select “yes”
6. Depending on the operating system PC may require rebooting
7. Allow Windows to register Phoenix components
8. Open Phoenix and update your prommer with the latest software included in this
9. Use the latest available product specific data packages or flash bundles with new
multi-protocol Phoenix.
ลิงค์หัวข้อ: http://wintesla2003.com/topic/26484
"ความพยายามอยู่ที่ไหน ความพยายามก็อยู่ที่นั้น"
จำหน่าย user Nokia , SX-4 , FPS-10 , FPS-20 , FPS-21 , รับเปิดคำสั่ง GSM ใน PKD-1 , FLS-4 , FLS-5 แบบถาวร * สนใจติดต่อได้ครับ 081-3772760
DIGITAL
คะแนนขอบคุณ: 37
Member ID : 2989
Time Online : 9:15:22
Level 15 : Exp 15%
PD: 0.082
กระทู้: 351
« ตอบ #1 เมื่อ: 27 กุมภาพันธ์ 2551, 09:23:38 »
กว่าจะหาซื้อมาได้   ...ขอไปลองหน่อยแล้วกันครับ
คะแนนขอบคุณ: 377
Member ID : 223
Level 19 : Exp 61%
PD: 0.128
กระทู้: 589
« ตอบ #2 เมื่อ: 27 กุมภาพันธ์ 2551, 09:38:29 »
ไปซื้ออะไรมาหรือครับพี่ บอกกันบ้างซิ
AppSpp^
หมายเลขสมาชิกท่านคือ 1026
Msn : Gogo_pub@hotmail.com
คะแนนขอบคุณ: 62
Member ID : 475
Time Online : 21:2:34
Level 30 : Exp 8%
PD: 0.303
กระทู้: 1371
« ตอบ #3 เมื่อ: 27 กุมภาพันธ์ 2551, 10:45:13 »
อ่านมะออกอ่ะ ต้องใช้ดองเกิล อย่างเดวป่าวคับ ถ้าตามข้อ 4
ร้านเดอะโฟนบ้านดู่ เชียงราย
ช่วงหลังไม่ค่อยได้เข้าเว็บเลยครับ เอาใว้ยังไงจะแวะมาเรื่อยๆนะคับ
เซทบอทขายเอ็มเพลินเลย อิอิ
jojoe^
Member ID : 111
Time Online : 28:4:1
Level 15 : Exp 38%
PD: 0.078
กระทู้: 363
« ตอบ #4 เมื่อ: 27 กุมภาพันธ์ 2551, 14:18:59 »
JL_KMK
Member ID : 4424
Time Online : 1:17:41
Level 4 : Exp 51%
กระทู้: 32
« ตอบ #5 เมื่อ: 14 เมษายน 2551, 13:48:46 »
