18 กุมภาพันธ์ 2562, 02:04:23
ผู้เขียน หัวข้อ:  Phoenix_Service_Software_2008_4_7_32837 ตัวใหม่สุดครับ  (อ่าน 2770 ครั้ง)
ยุทธนาปราจีน ซ.บุญปลูก
.:: NokiaOnlineKICS ::.
.:: I-Mobile Support ::..:: LG Support ::.
คะแนนขอบคุณ: 377
Member ID : 223
Time Online : 33:23:40
Level 19 : Exp 61%
PD: 0.128
กระทู้: 589
« เมื่อ: 6 พฤษภาคม 2551, 02:05:24 »
Phoenix_Service_Software_2008_4_7_32837 ตัวใหม่สุดครับ ตอนนี้
ใช้งานดีมากครับ flash ได้ไวกว่าตัวเก่ามากครับ
download Phoenix_Service_Software_2008_4_7_32837
Nokia APAC NOL
6 (1)
CONFIDENTIAL
APAC TECHNICAL SUPPORT Create Date
Wilchua 22 April 2008 ASB<MPP>031
CMO/DFC_SW_TB-12 Page 1 of 6
MULTI PROTOCOL PHOENIX SERVICE SOFTWARE
2008.4.7.32837
INTRODUCTION
Update version of Phoenix service software is available. This multi-protocol service software
supports Nokia CDMA, GSM, TDMA, and WCDMA products. Please see product specific
technical bulletins for phone model specific information and instructions.
Service SW installation packages, TBs, and product specific technical bulletins are available in
NOL.
IMPORTANT
You must uninstall the older version of Phoenix before installing this release.
If you are installing this version of Phoenix on a new Imaged PC, and you are using an
FLS-4S or FLS-5 during the install, then install the FLS-X drivers first.
In order to Use FPS-11, you may need to install a separate package, which can be found
in NOL.
This installation package contains the following components:
- Connectivity Cable Driver v 6.86.10.0
- Flash Update 08.06.001
- FLS-x Drivers v 2.09.17
- DK2 Dongle Driver v 7.14.0.25
Minimum Recommended PC HW Requirements:
- Computer Processor: Pentium 4 or above or equivalent
- RAM 1GB
- Minimum free hard disk space 100 GB depending on installed product data packages.
Supported Operating Systems:
- Windows 2000 Service Pack 4 or higher
- Windows XP Service Pack 1 or higher
When installing Phoenix into Win 2000 or XP you must have local admin rights.
For using the Phoenix in Win 2000 or XP, user must have power user rights.
After installing Phoenix Service Software version, please install the latest product
specific data packages or SW bundles.
Nokia APAC NOL
6 (2)
CONFIDENTIAL
CMO/DFC_SW_TB-12 Page 2 of 6
Supported Models
The list of supported models is available once Phoenix is installed by navigating to the
Open Product under the File menu.
Changes in version 2008.4.7.32837 for GSM/WCDMA phones
New features and error corrections:
• Firmware update user interface (UI) has changed. The New UI has buttons for “restore
user product” and “refurbish” see figure 1 on pg 6.
• New product add
o RM-387, RM-364, RM-365, RM-366, RM-354, RM-355,RM-429,RM-343, RM-
345,RM-346, RM-357,RM-425, RM-247, RM-297,RM-235, RM-236, RM-
342,RM-401,RM-378, RM-379,RM-325, RM-426,RM-381,RM-427,RM-410, RM-
411,RM-352, RM-353, RM-420 ,RX-48, RM-333, RM-334, RM-335, RM-435,
RH-112, RH-113, RH-114, RH-115 RM-392, RM-393 RM-398, RM-399 RM-407
RM-396, RH-118, RM-356, RM-414, and RM-448
Known Errors
• None
Nokia APAC NOL
6 (3)
CONFIDENTIAL
CMO/DFC_SW_TB-12 Page 3 of 6
Changes in version 2008.4.7.32837 for CDMA phones
• None
Known Errors
• Some CDMA models may not be able to flash and refurbish with FLS-4 and FLS-5.
• FPS-11 should not be used to revive “dead” Phones.
General information
• First time Phoenix installation may take a longer time.
• Auto creation of phone data XML-file is an alternative of the fault-log module, and the
path for saving the XML files can be modified with the new UI under
Tools>Options>Phone Info XML files setting menu.
• Rebuilding IMEI/ESN, SIM lock requires Smart card, SX-4 with rebuild access rights
enabled. Please send your SX-4's serial number to your regional security officer if you
need these rights.
• Rebuilding ESN/IMEI with FPS-8 now requires a SX-4 card to be used. An external
smart card reader is needed when using the FPS-8.
• Auto-tuning requires a user registered and activated SX-4 card.
• Changing product codes and restoring certificates in BB-5 products may require the SX-
4 card to be reregistered with your security officer.
• BB5 products cannot generally be flashed using the FPS-8.
• Preferred connection to FPS-10 is by the LAN port.
• The preferred connection to FLS-4S is using the USB port.
• In order to use Willtek 4400 for auto tuning, we recommend updating the Willtek with a
new PC; minimum firmware version of the Willtek 4400 must be ver.12.30. For further
information and required HW options please contact your local Willtek sales
representative or e-mail to mailto:support@willtek.com
• NFPD (Nokia Flash Prommer Device) is the new connection name for FPS-10 and the
coming flash prommer connection.
Nokia APAC NOL
6 (4)
CONFIDENTIAL
CMO/DFC_SW_TB-12 Page 4 of 6
Assemblies Affected
All GSM, WCDMA, TDMA, and CDMA phone models mentioned on page 2 of this
technical bulletin.
Special Equipment:
In order to use Phoenix with phone models supported by it, you need to use
1. Latest Phoenix Service Software 2008.4.7.32837 or newer, which includes all
needed drivers and flash support files.
2. Latest phone model specific Phoenix Data Package or Flash Bundle
3. Flash Update Package for FPS-21/FPS-10/FPS-8/FLS-4S/FLS-5 (v 08.06.001 included
in the package)
4. JBV-1 Software Update v 18 or newer (See ASB_AST_009.PDF (NOL > Support
Library > APAC – Service Software & Bulletin > Drivers & Bulletin > JBV-1 & Bulletin);
not valid for JBV-1 RoHS compliant)
5. Parallel Port Driver for FPS-8 if you experience slow file transfer speed via LPT port
(See ASB_AST_071.pdf (NOL > Support Library > APAC – Service Software & Driver >
Drivers & Bulletin > FPS-8 General Bulletin))
6. PK-1 or PKD-1 Dongle (PKD-1NS for type label printing) OR FLS-4S/FLS-5 POS Flash
Dongle
7. Programming devices for updating the phone software
8. Phone model specific service tools
• A complete Phoenix service software installation package always includes the
latest drivers and flash update files available at the time of the release.
• Please use separate driver or flash support file installation packages only if
updates occur between complete Phoenix releases.
For details of installing each package, please refer to phone model specific Service Manuals
and Technical Bulletins concerning each mentioned update package.
Nokia APAC NOL
6 (5)
CONFIDENTIAL
CMO/DFC_SW_TB-12 Page 5 of 6
Procedure
How to install new Phoenix 2008.4.7.32837
1. Download phoenix_service_sw_2008.4.7.32837.exe application file to your
computer (e.g. C:\TEMP).
2. Close all other programs.
3. Run phoenix_service_sw_2008.4.7.32837.exe and follow instructions on the screen
to install Phoenix Service Software
4. Connect a dongle (PK-1, PKD-1, FLS-4S, FLS-5) when message appears on the
screen
5. If you are prompted to update any existing driver or file versions, select “yes”.
6. Depending on the operating system, the PC may require rebooting.
7. Allow Windows to register the Phoenix components.
8. Open Phoenix and update your prommer with the latest software included in this
installation package.
9. Use the latest available product specific data packages or flash bundles with new
multi-protocol Phoenix.
Notes
This product includes software developed by the OpenSSL Project for use in the OpenSSL
Toolkit (http://www.openssl.org/).
Copyright (c) 1998-2005 The OpenSSL Project. All rights reserved.
Copyright (c) 1995-1998 Eric Young (eay@cryptsoft.com). All rights reserved.
OpenSSL license text can be found from http://www.openssl.org/source/license.html.
Nokia APAC NOL
6 (6)
CONFIDENTIAL
CMO/DFC_SW_TB-12 Page 6 of 6
Figure1
ลิงค์หัวข้อ: http://wintesla2003.com/topic/36060
« แก้ไขครั้งสุดท้าย: 6 พฤษภาคม 2551, 02:12:51 โดย yutthana prachin »
"ความพยายามอยู่ที่ไหน ความพยายามก็อยู่ที่นั้น"
จำหน่าย user Nokia , SX-4 , FPS-10 , FPS-20 , FPS-21 , รับเปิดคำสั่ง GSM ใน PKD-1 , FLS-4 , FLS-5 แบบถาวร * สนใจติดต่อได้ครับ 081-3772760
oh^
คะแนนขอบคุณ: 10
Member ID : 524
Time Online : 13:7:27
Level 8 : Exp 87%
PD: 0.027
กระทู้: 123
« ตอบ #1 เมื่อ: 6 พฤษภาคม 2551, 13:32:26 »
ขอบคุณครับ adore
ช่างมั่วมือ1
มั่วได้ มั่วดี มั่วอย่างมีเหตุผล แล้วก็มั่วต่อไป
คะแนนขอบคุณ: 86
Member ID : 26
Time Online : 50:13:21
Level 16 : Exp 31%
PD: 0.087
กระทู้: 407
« ตอบ #2 เมื่อ: 6 พฤษภาคม 2551, 20:06:47 »
ขอบคุณครับ นำสิ่งดีๆมาให้ตลอดเลยครับ Grin Grin
P.J.MOBILE^
คะแนนขอบคุณ: 233
Member ID : 3855
Time Online : 36:6:23
Level 21 : Exp 8%
PD: 0.161
กระทู้: 676
« ตอบ #3 เมื่อ: 7 พฤษภาคม 2551, 19:49:25 »
ขอบคุณครับท่านยุทธ Smiley Kiss
adisak hamwong
Member ID : 1134
Time Online : 2:5:7
Level 2 : Exp 56%
กระทู้: 10
« ตอบ #4 เมื่อ: 9 พฤษภาคม 2551, 15:39:04 »
thk
เอที โมบาย
NT@Mobile Phrae
คะแนนขอบคุณ: 370
Member ID : 372
Time Online : 35:16:50
Level 24 : Exp 38%
PD: 0.198
กระทู้: 905
« ตอบ #5 เมื่อ: 15 พฤษภาคม 2551, 14:42:35 »
ขอบคุณมากๆ ครับพี่นา ขอบคุณครับ Smiley
Wintesla2003 Club Detial : http://www.wintesla2003.com/club/239
sumo_1
คะแนนขอบคุณ: 25
Member ID : 1575
Time Online : 2:48
Level 9 : Exp 19%
PD: 0.030
กระทู้: 130
« ตอบ #6 เมื่อ: 27 พฤษภาคม 2551, 11:26:17 »
 Cheesy Wink Wink
jamebb07^
คะแนนขอบคุณ: 74
Member ID : 6959
Time Online : 7:17:28
Level 16 : Exp 88%
PD: 0.112
กระทู้: 439
« ตอบ #7 เมื่อ: 29 มิถุนายน 2551, 15:44:57 »
Nokia APAC NOL
6 (1)
CONFIDENTIAL
2008.4.7.32837
INTRODUCTION
NOL.
IMPORTANT
in NOL.
- RAM 1GB
Nokia APAC NOL
6 (2)
CONFIDENTIAL
Supported Models
• New product add
Known Errors
• None
Nokia APAC NOL
6 (3)
CONFIDENTIAL
• None
Known Errors
General information
need these rights.
Nokia APAC NOL
6 (4)
CONFIDENTIAL
Assemblies Affected
technical bulletin.
Special Equipment:
in the package)
Dongle
Nokia APAC NOL
6 (5)
CONFIDENTIAL
Procedure
screen
Notes
Nokia APAC NOL
6 (6)
CONFIDENTIAL
Figure1
ตัวนี้เวลาลงต้องใช้ pkd1 หรือปล่าวครับ    พอดีไม่มีครับ   และที่ใช้อยู่ก็เป็นตัวแคร็ก  2007 ครับ   รบกวนขอข้อมูลหน่อยครับ  ขอบคุณครับ
click to comment" title="click to comment
โยกเข้าไป  ให้ชีวิตมัน มัน
