23 มีนาคม 2562, 16:40:56
ผู้เขียน หัวข้อ:  ..!! CruiserSuite TP Full Unlocker v1.00 released !!..  (อ่าน 1237 ครั้ง)
Audsky^
.:: I-Mobile Support ::.
มองอย่างนก บินอย่างนก และเป็นดั่งนก
คะแนนขอบคุณ: 6169
Member ID : 688
Time Online : 88:8:57
Level 46 : Exp 60%
PD: 0.725
กระทู้: 3288
« เมื่อ: 10 กรกฎาคม 2551, 08:51:38 »
Dear all,
we have just released most wanted SonyEricsson Full Unlocker via TestPoint with Security Zone repair possibility. The CruiserSuite TP Full Unlocker requires UC-20 TestPoint cable - you can buy it from any of our resellers.
All other TestPoint solutions force the phone address bus pins to 3.3V which is exceeding its maximal allowed voltage almost twice. Only the UC-20 TP cable was designed to prevent this and avoid likely flash chip damage.
Here are release notes of CruiserSuite TP Full Unlocker v1.00:
  • Simple to use & failsafe
  • Supports all DB2020 plattform based SonyEricsson phones
  • All current CIDs are suported
  • This software is for all users who can disassemble the phone - also for inexperienced ones. (For disassembling phones, we recommend to read proper SonyEricsson service manuals.)
  • TP Full Unlocker does not destroy phone calibration data (so typical for SeTool ... )
  • For the phone safety, TestPointing requires UC-20 TP cable.
  • Unlike other amateur solutions which use external battery connection to the TP, our software uses specially designed UC-20 cable which can handle different bus voltages and prevents any potential flash chip damage.
  • TP is done in two stages. Once you complete TP stage 1 you don't need to repeat it anymore. Phone is then bootable via the 2nd testpoint anytime.
  • PDF manual is available after installation as usual in Documents folder
You can download the software from our Downloads section or from this Rapidshare link.
ENJOY!
ลิงค์หัวข้อ: http://wintesla2003.com/topic/42458
