3 เมษายน 2563, 18:46:47
หน้า: 1 2 3 4 5 6 7    ลงล่าง
ผู้เขียน หัวข้อ:  ตารางเทียบเบอร์จอ LCD.เครื่องจีน(ผิดห้องหรือเปลาเนี้ย)  (อ่าน 62833 ครั้ง)
detphone
Member ID : 57721
Time Online : 12:29
Level 2 : Exp 34%
กระทู้: 8
Opera 9.80
« ตอบ #120 เมื่อ: 21 ตุลาคม 2556, 18:34:42 »
ลิงค์หัวข้อ: http://wintesla2003.com/topic/46884
firstktb
คะแนนขอบคุณ: 1
Member ID : 68337
Time Online : 7:16
Level 1 : Exp 72%
HP: 0.7%
กระทู้: 4
Chrome 51.0.2704.103
« ตอบ #121 เมื่อ: 29 มิถุนายน 2559, 23:45:33 »
4 PCBA Repair Analysis
DP1T1 project is a low cost 3G smartphone,PCBA can be divided into following functional parts,
including:
1. CPU. U301 (PXA935) is a sigle chip solution for application and communication purpose,
which acts as the control center of whole handset and achieves all functions of the phone.
2. Power management part. U601 DA9035 supplies the powers for U301,memory and RF part.
3. Charging circuitry. U602 ISL6294 is battery charging circuit.D801 and D802 are charging
LEDs.
4. RF circuitry. U101, U102, U103, X101, U201-U209,CN101 are the main RF chips. U103 is a
highly-integrated quad-band EDGE transceiver; include phase-lock loop, VCO, LNA and RF
modulator/demodulator etc. U102 is a power amplifier with power control function. It is
mainly used to amplify the transmission signals from U103. U101 is a switchplexer for GSM
quadband and UMTS1/2/3 band, which controls RF transmission and receiving. CN101 is a
switch of RF test, mainly for production test purpose. X101 is a 26MHz oscillator, which
provides the standard 26MHz frequency reference to RF phase-lock loop and
U103.U201-U209 are WCDMA RF parts,only BAND1 2100MHz is supported.
5. Memory part. U701 is the memory for application and communication use. U701 is a 4Gbit
NAND +2Gbit DDR memory combo, which stores programs and data for U301. CN701 is a
memory extension interface for the plug-in T-flash card.
6. Display part. 3.2 inch WVGA TFT LCD is used.U907,U908,U909,U910 is ESD and EMI
filter for LCD signals.CN901 provides the interface to the LCD.U901 provides backlight
drive signal for LCD.
7. Camera part.U301, U903 and U904 are the main chips of this part. U301 provide camera
drive signal. U904 and U903 are applied to ESD protect and EMI filter the camera drive
signal. CN902 provides the interface to the 3M camera. CN903 is a VGA camera.U905,U906
provide power supplies to these two camera modules.
8. Audio circuitry part. Audio circuitry provides FM , ATVand MP3 playback, voice recording.
U601 is the main chip of this part.U603 is an audio amplifier.
9. Bluetooth and WIFI module. U1001, U1004 ,U1005 and ANT1002 are the main chips of this
part. U1001 is the bluetooth and wifi module. U1005 and U1004 provide power supply to
U1001.ANT1002 the wifi and bluetooth antenna.
10. GPS part.U1201 is the GPS chip.U1202,U1206 and U1207 is RF part of GPS.U1204 provides
power to U1201.X1201 provides clock to the GPS chip.
11. Keypad and OFN part. Keypad includes both the front keypad and side-keys. U301 provides
the row & column control signal. OFN signals are also from U301.Keypad backlight is
controlled by U601 KP_LED signal.
12. G-sensor light-sensor and compass. U801 is G-Sensor. U802 is e-Compass.U804 is light
sensor.They are controlled by I2C.
13. FM and ATV part. U1301 is the main chip of this part. U1301 integrates all FM radio receiver
functions and analog TV function. U1303 and U803 provide power supply to U1301.digital
signals of ATV are shared with camera.U1301 is controled by a dedicate I2C.
14. Data communication port,CN1101. Both USB port and serial port use this port.CN702 is
simcard interface.
6
15. Headset interface, CN1102. Headset is plugged into this audio jack.
16. Touch interface. Capacitive touch lens is used in DP1T1.CN801 is the interface between U301
and touch-lens module.U803 provides power to the touch module.
PakCity2012
คะแนนขอบคุณ: 2
Member ID : 69260
Time Online : 2:27
Level 3 : Exp 8%
PD: 0.011
กระทู้: 14
Chrome 43.0.2357.124
« ตอบ #122 เมื่อ: 17 พฤศจิกายน 2559, 15:16:28 »
ทำไมผมไม่เห็นครับ thank you
ps521437
คะแนนขอบคุณ: 2
Member ID : 65514
Time Online : 6:23
PD: 0.004
Windows NT 6.2
Firefox 50.0
« ตอบ #123 เมื่อ: 9 ธันวาคม 2559, 10:03:39 »
jaruwat
Member ID : 8506
Time Online : 2:3:41
Level 2 : Exp 11%
กระทู้: 6
Chrome 63.0.3239.84
« ตอบ #124 เมื่อ: 13 ธันวาคม 2560, 07:41:08 »
หน้า: 1 2 3 4 5 6 7    ขึ้นบน
