18 กรกฎาคม 2561, 11:32:30
ผู้เขียน หัวข้อ:  Dead Flash Nokia BB5 Devices via Phoenix Service Software 2009  (อ่าน 2335 ครั้ง)
FixPhoneLamnarai^
..:::Support File By Wintrsla2003:::..
คะแนนขอบคุณ: 8145
Member ID : 5281
Time Online : 108:14:6
Level 52 : Exp 67%
PD: 1.090
กระทู้: 4197
« เมื่อ: 3 ตุลาคม 2552, 08:57:49 »
This is a guide for those who have a dead Nokia device that needs to be revived back to life.
Symptoms: white screen - white screen with Nokia logo - doesn't turn on
I will NOT be held responsible for any damage done to your Nokia device by using this guide.
Continue at your own risk...
Step 1
Download Nokia firmware from here
NOTE: Always download the latest version. Using old version will result in phone not been fixed!
Step 2
Install the Downloaded firmware from Step 1.
Step 3
Download Phoenix Service Software 2009 from here
Step 4
Install Phoenix Service Software 2009 from Step 3.
NOTE: If your Antivirus/Internet Security prompt any alerts please make sure you give it access.
Step 5
Run Phoenix Service Software 2009.
NOTE: May take a while to load the application.
Step 6
Click on File > Manage Connections
Step 7
Make sure only NO CONNECTION is in that list. If there is anything else please delete and the click on Apply > Close.
Step 8
Click on File > Open Product
Step 9
Select your Nokia device and click on OK.
NOTE: If you don't know what your model is then switch off your phone and take your battery out and you will see a label with the Model details.
Step 10
Click on Flashing > Firmware Update
Step 11
Click on the ... button.
Step 12
Select 1 firmware variant from the list and Click on OK.
NOTE: Would recommend you to select APAC 1 or APAC 2 or APAC 3 or EURO 1 or EURO 2 or EURO 3 as these are the none branded firmware.
Step 13
Connect your phone via USB.
Step 14
Tick the "Dead phone USB flashing" and then Click on Refurbish.
Step 15
If you get any error message just ignore and Click on Yes.
Step 16
It will ask you to Press phone power button. Just hold the power button for a few seconds.
NOTE: This will NOT work if your battery is empty. If this does not work try a different battery that is charged.
Enjoy!
You can now close Phoenix Service Software 2009. You Nokia device should boot up by itself. If it does not boot up then press the power button to power up your device.
ลิงค์หัวข้อ: http://wintesla2003.com/topic/99330
1  *
รับงาน ส่งซ่อม Hardware&Software
สอบถามโทร : 080-2619914 (ตั้ม)
ซ่อมไม่ผ่านไม่คิดเงิน
รับปลดล็อค iPhone4/4S/5 3GS 6.x.x LL ราคาพิเศษ
Jr_อุทุมพรพิสัย
คะแนนขอบคุณ: 646
Member ID : 730
Time Online : 121:9:29
Level 27 : Exp 9%
PD: 0.260
กระทู้: 1113
« ตอบ #1 เมื่อ: 3 ตุลาคม 2552, 09:05:08 »
ขอบคุณมากครับ
hong_2000^
มั่วไปมั่วมา ก็ได้ตังส์
คะแนนขอบคุณ: 70
Member ID : 4639
Time Online : 38:13:58
Level 9 : Exp 71%
PD: 0.038
กระทู้: 147
« ตอบ #2 เมื่อ: 9 ตุลาคม 2552, 11:24:56 »
DCT4 ได้ไม๊ครับ
